Pdelcast
Pdelcast's Avatar
08.12.2010, 03:40 PM
Originally Posted by nuz69 View Post
It is the same screws of the REAR endbell I meant, the front endbell on the NEU-CC 1515/1y has stronger screws longitudinally mounted. I thought you change the system on the 1:10 scale motors for this reason, sorry.
I broke a motor front endbell with this system (ORION 2300Kv 4 poles), but the motor was hold by the front endbell, if in the HPI chassis the motor is mounted with front and rear fixation they should be no problem...
Also, the front end-bell is glued in place, so there shouldn't be any issues.
Patrick del Castillo
President, Principle Engineer
