respirologyrc
10.06.2010, 04:40 AM
you will need to find someone who can make you a rear center drive shaft if you plan on doing this. The G4 as you know uses the mono drive shaft. So if you go longer with the mono you will need a drive shaft that is the length of the mono shaft plus an additional 25mm long (25mm to compensate for the added length of the mono). Your truck looks good!!!!!!!
