nitrostarter
nitrostarter's Avatar
10.08.2010, 10:46 AM
In order to use the servos on the same signal, you just need a Y-harness to plug them into and then plug into the receiver.
Depending on which way the servo makes the wheels turn, you may have to rotate the servo to get the correct swing in the rear.
N. Rustler conversion
