4 wheel steering Savage
nitrostarter
10.08.2010, 10:46 AM
In order to use the servos on the same signal, you just need a Y-harness to plug them into and then plug into the receiver.
Depending on which way the servo makes the wheels turn, you may have to rotate the servo to get the correct swing in the rear.
N. Rustler conversion
nitrostarter
Find all posts by nitrostarter
2
Soro
Flux Fan
10.08.2010, 10:51 AM
Originally Posted by
nitrostarter
Is that all
Savage Flux 5mm TCS TVP with 8 Big bore shock conversion : Savage Flux XL TCS TVP with 4 IRC shock conversion
Soro
Find all posts by Soro
3
bryan
10.08.2010, 11:58 AM
I dont know what transmitter/reciever youre using.You may be able to use an aux. channel.That way you will be able to fine tune the rear steer to your liking.
bryan
Find all posts by bryan
Hybrid Mode
Switch to Threaded Mode
Off
