Finnster
KillaHurtz
Finnster's Avatar
10.08.2010, 09:06 PM
Originally Posted by _dV View Post
Steal away if it's gonna help. It's a pretty simple mod and the cutout for it is bridged by the steering post behind it so the TVP structure isn't really compromised. I haven't had anything hit\damage the exposed steering in a decent amount of varied driving either, the location makes that unlikely i think.
Will be great to see some vid of it when finished. I enjoyed watching the vid of your previous 4WS build and its unusual look when turning.
Btw, you might find that with the cutout you have for the slipper that rocks will get stuck under the adjustment ring as its diameter is much larger that of a normal center diff case. That's why my cutout is as wide as it is.
Thanks for the tips. :) The little platform is just a temporary solution just for fitting purposes. I'll be sure to cut the final plate larger if/when I actually get to that point!
I'm glad you liked the vid. It was pretty short and crummy, but just something to show the 4ws in action. Meant to make another vid, but have barely drove it this yr.
