12.03.2010, 11:38 PM
PM thomas if he has any spare rotors
Will do, thanks Chris.
Originally Posted by coolhandcountry View Post
What is the bolt pattern on these motors?
Yeah, 25mm spacing, but not sure on the bolt sizes, might be m3 as I did not have to buy the m4 thread size for my tdr lst motor mount.
Pretty sure its standard 25mm spacing, also pretty sure it uses M4 bolts for mounting.
I wouldnt worry about the home-brew 6mm > 5mm shaft, so long as there is no slop in the pinion on the shaft, and the shaft is uniformly 5mm ( not shaped little skittle at a bowling alley )...
Yeah, mine is not quite perfect, and I would like a 5mm shaft as that is what they were "originally" spec-ed for when AI bought it. The grinding was just a quick fix so I could use it.
