1717 6mm shaft question
1717 6mm shaft question - 12.03.2010, 06:23 PM
Hello Patrick,
Was wondering if you had any sort of trade in program for those of us who got the 1717 motors with the 6mm shaft? I did "turn" mine down to 5mm but would prefer something factory done...
I remember this being mentioned a while back but I cannot find it.
Big thanks to the CC team!!
12.03.2010, 08:22 PM
PM thomas if he has any spare rotors
coolhandcountry
coolhandcountry's Avatar
12.03.2010, 09:35 PM
What is the bolt pattern on these motors?
Peace!
Country
Help support the
Rc-Monster
Buy here
12.03.2010, 10:30 PM
Pretty sure its standard 25mm spacing, also pretty sure it uses M4 bolts for mounting.
I wouldnt worry about the home-brew 6mm > 5mm shaft, so long as there is no slop in the pinion on the shaft, and the shaft is uniformly 5mm ( not shaped little skittle at a bowling alley )...
12.03.2010, 11:38 PM
Will do, thanks Chris.
Yeah, 25mm spacing, but not sure on the bolt sizes, might be m3 as I did not have to buy the m4 thread size for my tdr lst motor mount.
Yeah, mine is not quite perfect, and I would like a 5mm shaft as that is what they were "originally" spec-ed for when AI bought it. The grinding was just a quick fix so I could use it.
