01.04.2011, 02:17 AM
Originally Posted by josh9mille View Post
Im not sure where you got the idea that the hubs and carriers are different? That is news to me if its true.
EDIT: maybe its because the flux and XL have bigger diameter axles? 8mm on flux/XL vs whatever the X has?
See the above quote, I guess they mean the hub when they say "uprights"???
According to the manual the X uses the same bearings that the flux and xl use, so the axle is the same size... The X does use the shiny axles, dogbones and diff outdrives and those are not that strong...
I do not think there is any difference, the arms, hubs and carriers are all the same part numbers.
