thzero
02.10.2011, 07:41 PM
It might, but it might even with the bulkhead there. Most of the truggies I've seen don't have the pin through a bulkhead but rather are mounted like Linc put it together as it allows you to adjust the toe-in for the rears and some other settings.
Do you think the hinge pin could bend as it is not supported in the middle by the bulk?
Unless I miss my guess the LST CVDs probably have a 8mm ball which is fairly standard on 8th scale vehicles so should work without any issues. The "SHD" axles use a 9mm ball.
i know that the LST CVDs are too small for the SHD savage axles... i am just wondering.. .do you think the vorza diff axles would work? the only reason i say, is because i just got a pair of vorza diffs and considering they use the tougher Hotbodies internals than the stock savage spider gears, i was just going to install the BP ring and pinion and be done with it... ???
