feistyacorn
feistyacorn's Avatar
03.28.2011, 11:22 AM
Originally Posted by BIG-block View Post
What charger are you using Jerry? Most chargers these days can take more than 12V and all the big power chargers need at least 24V. The PowerLab8 will not be able to charge at much more than 500W with only a 12V input regardless of the current that that the PSU can supply. In fact the PowerLab8 can handle up to 32V.
For you if you have a high end charger you are better off getting something like this PSU. CLICK HERE Mean Well have a pretty solid reputation from what I can gather reading the net. Also the unit in the link is switchable between 120V and 240V AC so you should be able to take it anywhere around the world.
I am leaning towards this unit. CLICK HERE. It should be a pretty close match for the PowerLab8. The only thing about it is that it isn't meant to operate below 180V AC so it wont be much use to you guys in US. For me it will be perfect.
That second Meanwell looks nice! I sent a email to Revolectrix a while ago asking about PSUs. They like Meanwell, Mastech, and Iota. I was looking at getting this Iota. I might end up getting this one because it looks like the 24v 40amp unit requires a 120v 20amp line. I'm not sure what our track has for power, but it would require me to add a 20 amp line to my hobby room. What are others doing for the PSUs that are "high watt"?
