Balancing Port Wires- Misconfiguration Results.
MindThoughts
Balancing Port Wires- Misconfiguration Results. - 04.21.2011, 07:47 PM
Yikes-
Will you please tell us exactly what you did, in order that we may avoid such a mistake?
PS. I'm glad you didn't get your fingers burned, nor get a shock. I'm also glad your charger is still working properly :)
I thought I blew the charger, by messing up the balancing wires while the charger was active. I didn't blew fuses, but did hear some popping. Long story short, I opened the bad boy and saw that the current limiter was popped. I was only able to charge through the balancing cables. Digikey to the rescue and all is well again. This time I bought me some parallel balancing adapters to prevent me from goofing off again.
Hyper 9E And Losi 8ight-E. Each model with Full Matrix Concepts Inc Carbon Fiber Chassis & Kit. Xcelorin 2100kv + Xcelorin ESC & 1409 1Y Neu/Castle + MMM. 1344watt 40amp PowerLab 8.
