rcanka
rcanka's Avatar
07.07.2011, 07:47 AM
Originally Posted by _dV View Post
some good mods to create more stable handling.
why choose a large servo when you could have gotten the same torque from a standard size one? most standard sized titanium geared are durable enough. do you drive it from the ESC BEC?
50K rear and 30K front ..most ppl go the other way around though i usually put the same in both being primarily an offroad basher.
IMO the bashcat braces and especially the titanium shocks shafts are not needed. just my opinion though. I also would have went with offset wheels instead of the longer axles
Badlands stretched over half ups you are probably lacking compliance over small bumps. Unfortunately there are no really good MT tires available.
cool vids
Recommend mod - shock tower supports since your layout has nothing obstructing it.
Large scale servo enabled me to not use a servo saver at all and the one i'm using is cheaper than the equivalent standard sized one.
I am using the ESC BEC, but if you can recommend me a better one I'd be one happy camper.
50k in the rear and 30k in the front is just because i like a little more oversteer than most :)
I'm thinking of getting trenchers, but what rims?
Also the shock tower support is an AWESOME idea, what did you use for it?
HPI Savage Flux HP, XL length, bashcat, ma1n5t, krakenRC, alza-racing...
Check out my YouTube channel for some excellent vids of mine and other beasts!
