_dV
07.07.2011, 06:41 AM
some good mods to create more stable handling.
why choose a large servo when you could have gotten the same torque from a standard size one? most standard sized titanium geared are durable enough. do you drive it from the ESC BEC?
50K rear and 30K front ..most ppl go the other way around though i usually put the same in both being primarily an offroad basher.
IMO the bashcat braces and especially the titanium shocks shafts are not needed. just my opinion though. I also would have went with offset wheels instead of the longer axles
Badlands stretched over half ups you are probably lacking compliance over small bumps. Unfortunately there are no really good MT tires available.
cool vids
Recommend mod - shock tower supports since your layout has nothing obstructing it.
rcanka
rcanka's Avatar
07.07.2011, 07:47 AM
cool vids
Large scale servo enabled me to not use a servo saver at all and the one i'm using is cheaper than the equivalent standard sized one.
I am using the ESC BEC, but if you can recommend me a better one I'd be one happy camper.
50k in the rear and 30k in the front is just because i like a little more oversteer than most :)
I'm thinking of getting trenchers, but what rims?
Also the shock tower support is an AWESOME idea, what did you use for it?
HPI Savage Flux HP, XL length, bashcat, ma1n5t, krakenRC, alza-racing...
Check out my YouTube channel for some excellent vids of mine and other beasts!
_dV
07.08.2011, 08:59 AM
The tie rods ends are standard Savage Flux tie rod ends. Joining them is a cheap m4 bolt. m3 bolt cut to size holds it to the chassis. You also need a longer shock bolt, think I used the same ones that go through the top of the roll bar.
47 spur with a 20 pinion will be about the same as the 44 with a 19 pinion. you might need to gear a bit lower then that. just keep an eye on your motor temps.
josh9mille
josh9mille's Avatar
07.08.2011, 05:45 PM
IMO the titanium shocks shafts are not needed. just my opinion though. I also would have went with offset wheels ]
I snapped off the of the stockers in the few outing with my flux, the ti-ni coated ones have been an excellent upgrade and I havent snapped any so far.
