08.05.2011, 07:18 PM
The aluminum rod I used for the towers wasn't the best quality stuff and was definitely weaker than the New Era towers I had. But good looking out and I really like your nylon rod idea anyway. Easy to work with, no worries that it'll bend or break towers and it should be alot cheaper in the long run compared to buying posts made for a stock truck.
Yeah, you can buy a meter / yard of nylon rod ( Delrin usually ) for a couple bucks which is enough to make a dozen or more posts, compared to one set of posts which costs ~$5 or so. Seen it done a few times over the years and it works & looks fine + very cheap ofcourse.
