mistercrash
Guelph, Canada, eh!
mistercrash's Avatar
10.05.2011, 01:50 PM
34AH SLA batteries would be a rough equivilent to 17AH in Lipos - Lead batterries are capacity rated at 20 hours discharge normally - they generally get about half their rated capacity when discharged at 1c. 13s would be a 48 volt Lipo setup. I would just go 12s or 14s myself.
My conversion yielded about 3/4 the volume, less than half the weight and 4 times the usable power vs the lead. I also gained slightly higher voltage and a HUGE difference in voltage under load(way more punch). The difference is huge.
This is getting better and better. So instead of 12 6s 5000 mah packs to have 30 amps, I could just go with 8 packs for 20 amps which would be more than enough. Even smaller, lighter and cheaper. With just 8 packs I might even be able to get Hyperions. So have you decided on how much these modules are going to go for? I'd like a snap on lid to protect the balance tabs please
And can you make a single module that can house 8 lipos? I figure that I would have to cut the bus bars.
No brain, no headaches.
