Chainsaw10
11.02.2011, 11:43 PM
Samintrepid, do you ONLY run 6s? Do you do much bashing/jumping or mostly speed runs? I'm surprised MY diff gears have held up with the abuse it has taken, but I only run 4s ...although I bumped up the gearing a bit with a metal 48 tooth spur gear.
I left the front and rear diff fluid alone so far but I put 100,000 weight Mugen silicone diff fluid in the center.
