Chainsaw10
11.02.2011, 11:43 PM
Samintrepid, do you ONLY run 6s? Do you do much bashing/jumping or mostly speed runs? I'm surprised MY diff gears have held up with the abuse it has taken, but I only run 4s ...although I bumped up the gearing a bit with a metal 48 tooth spur gear.
I left the front and rear diff fluid alone so far but I put 100,000 weight Mugen silicone diff fluid in the center.
samintrepid
samintrepid's Avatar
11.03.2011, 12:04 AM
Hello Chainsaw10, if you check my other video on youtube you can see the truck running on 4S turnigy 4500 30C. The truck take a jump on 4S and 6S without problem but most of time i run in front of my house on asphalt, grass and gravel.
I think you will break you center spider gear in the near future because i have chipped mine on 4S with 50, 000 weight (more wheelie but more stress on spider). Thunder tiger recommend 8000 weight in the center.
