samintrepid
samintrepid's Avatar
11.03.2011, 12:04 AM
Originally Posted by Chainsaw10 View Post
Samintrepid, do you ONLY run 6s? Do you do much bashing/jumping or mostly speed runs? I'm surprised MY diff gears have held up with the abuse it has taken, but I only run 4s ...although I bumped up the gearing a bit with a metal 48 tooth spur gear.
I left the front and rear diff fluid alone so far but I put 100,000 weight Mugen silicone diff fluid in the center.
Hello Chainsaw10, if you check my other video on youtube you can see the truck running on 4S turnigy 4500 30C. The truck take a jump on 4S and 6S without problem but most of time i run in front of my house on asphalt, grass and gravel.
I think you will break you center spider gear in the near future because i have chipped mine on 4S with 50, 000 weight (more wheelie but more stress on spider). Thunder tiger recommend 8000 weight in the center.
