12.01.2011, 10:29 AM
The car does have an al chassis, all of the plastic chassis parts are basically an undertray for aerodynamic assistance. Plus they have a motor cooling duct on one side, that may also generate some down force.
I think you guys need to take a better look at this, they put alot of thought and design into it.
The diffs are the revo spec ones with the steel supports inside, and they are running a set of 1/8 buggy tires/wheels, which weigh at lest 2/3rd less than a std MT tire/wheel. Wheel and tire weight-force kills diffs. If the diffs are correctly assembled and the ring/pinion mesh is good I do not see why the diffs will have any issues.
I built a slayer a while back and ran the snot out of it, buggy wheels with buggy badlands. Never had the slightest bit of diff or driveshaft trouble, even after breaking numerous arms and blowing tires of the wheels. I really think the diffs will not be an issue here.
My concerns center around how strong the chassis will be, flexibility wise. I see they have a center support that the center driveshaft passes thru, and a top deck of some sort. Hope that keeps the flex down to a minimum.
And the 1717 on 6s will be plenty of motor to get 10lbs or so up to 100mph. Not so sure the 25c traxxas lipos will hold up, would prefer to see some 40c lipos there. I will be keeping the dual tray setup, as even weight distribution is key to going fast and being stable.
