Thirdgen89GTA
You can sleep in a car, but you can't race a house
Thirdgen89GTA's Avatar
01.11.2012, 05:46 PM
Just grind the set screw flat so it will have a bigger surface area to "grab" into the shaft. I do this on all my set screws and no problems so far.
Went ahead and did this (easiest/fastest thing to check). Issue is so far fixed and I didn't have to modify anything.
Remains to be seen how long it lasts but I bashed pretty hard on 6S last night and had lots of on/off/brake cycles to stress the driveline and the pinion is currently in the same place it was when I started.
  • 1989 Pontiac TransAm GTA, 5.7L LT1/M6 400rwhp+
    • Jammin X1 CRT Pro, MMM/1717, 6S
    • Hyper One Seven 1/7th scale GT car, MMM/1717, 6S
    • Hyper 10TT, MMP/1410, 3S
    • TL Mini 8ight, stock, 2S
  Send a message via AIM to Thirdgen89GTA
