ta_man
01.22.2012, 09:12 AM
You will always have that startup cogging with those roar type motors trying to run sensorless. You can reduce that effect with gearing and startup power, but to me that just sucks as you can't get the full potential out of the motor. The 4 pole sensored motors work just fine in sensorless.
Tech guy I knew a long time ago said "Generalizations are never true."
I think it depends on the motor. I ran a Novak 8.5 (2 pole slotted) motor on an original Castle sidewinder for a while in a 2WD off-road truck and I thought it ran better than when I was using it with a sensored ESC.
