snellemin
2 KiloWatt RACER
snellemin's Avatar
01.19.2012, 11:29 AM
You will always have that startup cogging with those roar type motors trying to run sensorless. You can reduce that effect with gearing and startup power, but to me that just sucks as you can't get the full potential out of the motor. The 4 pole sensored motors work just fine in sensorless.
6 KiloWatt A123 Racer
24s2p EVG SX 49.6mph Ebike.
ta_man
01.22.2012, 09:12 AM
Tech guy I knew a long time ago said "Generalizations are never true."
I think it depends on the motor. I ran a Novak 8.5 (2 pole slotted) motor on an original Castle sidewinder for a while in a 2WD off-road truck and I thought it ran better than when I was using it with a sensored ESC.
snellemin
2 KiloWatt RACER
snellemin's Avatar
01.22.2012, 10:23 AM
What rotor where you using in that 8.5T motor?
I got around the cogging with a 12.5mm rotor and some more voltage with my 2.5T motors. The LRP with 14mm rotor is a hard one to start up in sensorless.
ta_man
01.22.2012, 10:29 PM
IIRC, standard 12.3 rotor.
