Thirdgen89GTA
You can sleep in a car, but you can't race a house
Thirdgen89GTA's Avatar
03.09.2012, 02:59 AM
Originally Posted by scarletboa View Post
i never had steel diff internals. when i go to order the replacement gears, whether they are the x1 or x2 gears, they are still aluminum. the only ofna gears i could find for this truggy are aluminum. i went ahead and ordered some diff gears from a HotBodies Lightning. the gears have the same amount of teeth and look the same as the stock ones. hopefully they work.
I thought the internal gears on the X1 were hardened steel. The aluminium CNC cross pins are the upgrade part. But I've never needed them.
Give www.nitrohouse.com a ring. They're great to talk to about upgrade parts for the Jammin's. Nexx8T parts should be similar. OFNA dropped the Jammin name, and the Nexx8T is essentially the Jammin X3 CRT.
  • 1989 Pontiac TransAm GTA, 5.7L LT1/M6 400rwhp+
    • Jammin X1 CRT Pro, MMM/1717, 6S
    • Hyper One Seven 1/7th scale GT car, MMM/1717, 6S
    • Hyper 10TT, MMP/1410, 3S
    • TL Mini 8ight, stock, 2S
  Send a message via AIM to Thirdgen89GTA
