scarletboa
scarletboa's Avatar
03.09.2012, 02:53 AM
Originally Posted by Thirdgen89GTA View Post
I would just switch back to the steel internals. You won't really notice it as much as you'd think with BL power. I'm still using the original steel spider gears in my Jammin X1 CRT Pro. I've had some major modded engines in there for the last 5 years and they are still going strong.
The aluminium is great, but you have to pay to play with them. The alloy is just too soft for that kind of application. 1/8th scale's put a ton of stress on components. Its amazing that they are as durable as they are.
i never had steel diff internals. when i go to order the replacement gears, whether they are the x1 or x2 gears, they are still aluminum. the only ofna gears i could find for this truggy are aluminum. i went ahead and ordered some diff gears from a HotBodies Lightning. the gears have the same amount of teeth and look the same as the stock ones. hopefully they work.
