03.12.2012, 10:04 PM
With the diff assembled if there is any in/out play in the diff cups you need to shim behind the sun gears to take that play out.
With the diff unassembled you can drop in a sun gear and see where it hits the planetarys. If you feel the mesh could be tightened then shim behind the planetarys.
