Maxamps has discovered 2P packs (New Product, DUAL CORE!!!!)
brainanator
brainanator's Avatar
Maxamps has discovered 2P packs (New Product, DUAL CORE!!!!) - 06.28.2012, 06:21 PM
Got an email today showing off maxamps' brand new innovation! Taking something that's been around for a long time, and giving it a fancy name.
They call them, "Dual Core Lipos". (AKA 2S2P, etc...)
Originally Posted by http://www.maxamps.com/Lipo-8000-74-DC-Pack.htm
The 150C Dual Core pack offers the highest performance of any lipo battery available in the world. Rather than using one 8000mah cell, we take two 4000mah 150C cells and put them together in parallel. By doing this, the power load is split between two cells(cores) instead of one. Each cell has the thickest and lowest resistance tabs available. Not only do you get two cores, but you get 4 tabs instead of 2. This creates a pack with the lowest possible resistance, the highest voltage under load, and the most rapid voltage recovery of any pack we have ever tested.
50+mph in most brushless setups(7.4 volts)
True 150C rating
48 minutes average run time(8000mah capacity)
Lifetime Warranty
5C fast charge capable
100% waterproof
Built today with factory fresh cells
Built with genuine 12awg Deans Ultra wire
We add the connectors and balancing taps for you
137mm x 45mm x 33mm, 441g
