08.20.2012, 08:29 AM
Originally Posted by x-y View Post
the final rpm is irrelevant ...... the most important is use a correct motor/batt/gearing .....
if I use a leopard 4074 2000kv + 3s + correct gearing only will have 22-25k rpm .... and I will have the same top speed and lower temperatures than the 4065 2700+3s ....... the difference is will have more spent of energy and +70gr.....
yes what you listed is impt to keep components cool and to obtain desired speed. RPM does play into the efficiency of the setup. Correct gearing/motor choice will lead to a cooler running setup as well.
If you can obtain a cool running setup with a lower RPM, then you get the most run time out of your system... which is what I strive for in all my rigs.
