SV6000
SV6000's Avatar
06.06.2013, 12:13 PM
Ive ran the Hydra ice HV in a 1/5th scale on 12s, it does not need a pistix as it is meant for a boat so a pistol remote will work. You will need to have some mechanical braking setup and it needs fans to keep it cool or you can utilize the water cooling tubes. Another alternative is to remove the casing and purchase a XL2 case to put on it, they are the same case the XL2 has a fan mounted instead
CUBIC INCHES = CUBIC HORSEPOWER = CUBIC DOLLARS
