Thread: V1.46 questions
Pdelcast
Pdelcast's Avatar
12.18.2014, 06:23 PM
Originally Posted by Dr_T View Post
Thanks for your quick reply Patrick!
So, for limiting the magnitude of Current spikes, I should use the Torque limiter then, right? And what does "interrupting" PWM mean, setting throttle / motor input Voltage to zero?
Torque limit would be good for limiting current spikes during hard acceleration. The current limiter has just a couple settings, can't really be used as a general purpose current limit - -it's not designed that way. The PWM is shut down for several commutation cycles when it trips.
Thanx!
Patrick del Castillo
President, Principle Engineer
