Dr_T
Dr_T's Avatar
12.18.2014, 05:59 PM
They are not related. Current limit is a maximum allowed average current (to protect the controller) and interrupts PWM. Torque limit varies PWM to limit maximum torque from the motor. Torque limit does not use the same hardware as current limit.
Thanks!
Thanks for your quick reply Patrick!
So, for limiting the magnitude of Current spikes, I should use the Torque limiter then, right? And what does "interrupting" PWM mean, setting throttle / motor input Voltage to zero?
Pdelcast
Pdelcast's Avatar
12.18.2014, 06:23 PM
Torque limit would be good for limiting current spikes during hard acceleration. The current limiter has just a couple settings, can't really be used as a general purpose current limit - -it's not designed that way. The PWM is shut down for several commutation cycles when it trips.
Thanx!
Patrick del Castillo
President, Principle Engineer
