maxxximatoze
12.08.2017, 07:45 PM
Not surprising you didn't see a difference -- even in sensored mode, timing above a certain threshold is dominated by the sensorless routine. (which makes sense...)
You are probably close to the maximum 5 degree advance at 24V, so your rise in current is normal.
Thanks!
Patrick
OK good to know. I will try with 0 timing to see what append and report here...
