Pdelcast
Pdelcast's Avatar
12.08.2017, 02:44 PM
Originally Posted by maxxximatoze View Post
Thx for the answer. It was sensorless. I have tested both mode and no real differences between the two. The advance is set to low (0 to 5 if I remember well) with castle link.
Not surprising you didn't see a difference -- even in sensored mode, timing above a certain threshold is dominated by the sensorless routine. (which makes sense...)
You are probably close to the maximum 5 degree advance at 24V, so your rise in current is normal.
Thanks!
Patrick
Patrick del Castillo
President, Principle Engineer
