11.29.2006, 05:00 PM
You can pop off the end where the power wires go in. To take the other end off, you need to desolder the motor wires. You can try to slide the top plastic plate off, but there is a surface mount cap by the button that may get ripped off (happened to me). You can also simply pry on one side until the plate comes out of the groove. Either way works.
Oh, and a final warning; this will most definitely VOID THE WARRANTY! Do at your own risk...
