12.25.2006, 08:02 PM
Originally Posted by GriffinRU
After playing for some time with REVO adapters found out that rear motor support is the most important thing.
I like this setup, as being close to ideal
Artur
Personally, I like the first one better. It uses 6 screws to hold the mount down. The second one relies on only 4 screws into the relatively weak stock motor mount. I do like the rear support though, but it seems it only works for a certain motor length.
(@GriffinRU: The first setup is what I PM'd you about)
To support the rear of the motor in my current design, I just wedged a thick piece of rubbin between the underside of the motor and the mount. Not the prettiest, but it worked. :)
