12.25.2006, 08:02 PM
Originally Posted by GriffinRU
After playing for some time with REVO adapters found out that rear motor support is the most important thing.
I like this setup, as being close to ideal
Artur
Personally, I like the first one better. It uses 6 screws to hold the mount down. The second one relies on only 4 screws into the relatively weak stock motor mount. I do like the rear support though, but it seems it only works for a certain motor length.
(@GriffinRU: The first setup is what I PM'd you about)
To support the rear of the motor in my current design, I just wedged a thick piece of rubbin between the underside of the motor and the mount. Not the prettiest, but it worked. :)
GriffinRU
12.27.2006, 06:20 PM
This one right?
Artur
Name:	revo adapter.JPG
12.27.2006, 06:50 PM
This one right?
Artur
Yup, that's the one...
Although, if it's easier, I don't think I need the pivoting base since the motor itself can be adjusted by the slots...
GriffinRU
12.27.2006, 11:57 PM
Any thoughts on this support?
Artur
P.S. flip support 180 to match mounting holes...
12.28.2006, 12:25 AM
Yeah, that looks like it could work nicely! :027: The only thing to remember is to adjust the support when you adjust the mesh, but that's no biggie. I'd probably add a thin layer of foam or some type of cushion to keep from scratching the motor, but that's easy to do.
You haven't by any chance made a stronger mount did you? I mean the longer parts that go over to the bulkhead ends and supports the stock pivot point. It seems to be made of pot-metal or something.
GriffinRU
12.28.2006, 11:24 AM
What about making them from plastic (delrin...)
You can set it once and then set gear mesh with swing arm, like with Nitro.
No, I didn't. Do they fail?
Artur
12.28.2006, 11:35 AM
Artur
Plastic should work nicely for the rear support as long as it's ~3mm+ thick. And I don't think it necessarily has to be delrin, but that sure would work.
Actually, I wasn't planning on using the "swing-arm" Nitro mesh adjustment. It is made for a pinion that sits under the spur really. The traditional slotted holes you made would be better IMO since the motor sits more to the side. I guess you could use the swing arm mesh adjustment to tweak the angle of the mount to suit personal preference though.
I've never heard of a broken motor mount, even with using the 3.3, but it seems like it's kinda cheaply made. It does seem to hold though, so maybe I'm being too anal about it.
Oh, and apologies to Shark413 for hijacking his thread... :dft001:
