sapper_triple6
Student of RC-Monster University
sapper_triple6's Avatar
02.18.2007, 06:49 PM
Next Step: hybrid bulks, HB diffs, and 3.3 sliders
This was probably the biggest issue I had during the whole build. First of all I had to find a way to attach the 3.3 sliders to the diffs. After some help from some people on the forum I decided to use the output shafts from the sliders and dremel off the threaded part, then use these to replace the output shafts on the diffs. It works great!!! Perfect fit. I also had to modify the pinion to take a stock driveshaft. Not the easiest task in the world but I got it to work using once again the trusty dremel. I just kept grinding and testing until the driveshaft went on.
  Send a message via Yahoo to sapper_triple6
