For newbies, by a newbie
sapper_triple6
Student of RC-Monster University
sapper_triple6's Avatar
For newbies, by a newbie - 02.18.2007, 06:24 PM
First of all I want to thank everyone one this forum for helping me with my maxx project.
I just finished building my BL Maxx, and would like to describe my build for anyone with questions.
This is what I decided to install
-BK Warrior 9920
-Feigao 540C 9XL (7XL was out of stock)
-External UBEC
-FLM hybrid bulks with HB diffs
-Spektrum DX3.0 radio system
-Strobe slipper
-RPM Arms, Knuckles, and Shock Towers for T-Maxx 3.3
-3.3 Sliders
-Custom home built spur gear cover
  Send a message via Yahoo to sapper_triple6
Gundam-Guy
Gundam-Guy's Avatar
02.18.2007, 06:29 PM
sounds good lets get get a pic of it:018:
sapper_triple6
02.18.2007, 06:35 PM
First off was the motor and ESC. Everything went in easy except for the motor. I am still using the stock tranny since I cant find a single speed conversion, and I found that the can on the motor was hitting the tranny case and I couldnt get the proper gear mesh. Quick easy solution was taking the dremel to the fins that were hitting the tranny case. Problem solved.
During this step I also found that the stock spur gear cover no longer fits due to the strobe slipper. To solve this I just cut the face off the stock one and used some CA and polycarbonate and made it a little bigger.
The only problem with the ESC was finding a spot where I wanted to mount it. My own decision was to mount it where the stock Rx used to be. I used a dremel to cut out the sections of the chassis I needed to get rid of to give it a nice fit then held it on with some double sided tape.
To cool the ESC I just glued a 40mm fan to the fins and wired it to a 9V batt that I have stuck to the tranny case.
sapper_triple6
02.18.2007, 06:36 PM
Ill post the pics when I'm done with the write up.
sapper_triple6
02.18.2007, 06:49 PM
Next Step: hybrid bulks, HB diffs, and 3.3 sliders
This was probably the biggest issue I had during the whole build. First of all I had to find a way to attach the 3.3 sliders to the diffs. After some help from some people on the forum I decided to use the output shafts from the sliders and dremel off the threaded part, then use these to replace the output shafts on the diffs. It works great!!! Perfect fit. I also had to modify the pinion to take a stock driveshaft. Not the easiest task in the world but I got it to work using once again the trusty dremel. I just kept grinding and testing until the driveshaft went on.
sapper_triple6
02.18.2007, 06:53 PM
The rest of the build went pretty well my only other advice is to ask any questions you have, and be creative with your own ideas. If you want any pics of specific areas or parts just ask. It doesnt take a rocket scientist to figure this stuff out. Im proof, this is my first build.
sapper_triple6
02.18.2007, 07:04 PM
jnev
jnev's Avatar
02.18.2007, 08:37 PM
It is looking great. Have you got to try it yet? What would you estimate the speed and/or run time to be? Also, if you can, could you post a picture of how you installed the 3.3 sliders with the HB diffs?
Thanks
sapper_triple6
02.18.2007, 08:58 PM
I only got to try it for a couple runs until I went end over end and broke 2 shocks and a stock rear body mount so now im waiting for parts. Here is the link where I found the HB diff conversion for the sliders. http://www.rc-monster.com/forum/showthread.php?t=3588
and a pic of my not so pretty but fully functional pinion.
Mike.L
Mike.L's Avatar
02.18.2007, 09:04 PM
Looks nice am glad there wasnt any problems. Hope you had fun!
  Send a message via MSN to Mike.L
Nice! And I like the modded gear cover!
Originally Posted by sapper_triple6
...To cool the ESC I just glued a 40mm fan to the fins and wired it to a 9V batt that I have stuck to the tranny case.
If you want to get rid of that 9v battery, you can use this instead.
sapper_triple6
02.18.2007, 09:10 PM
i thought about that but I'm over here in germany at the moment and I'm not sure where to get all the parts to build it and I dont feel like paying the shipping to get it from radio shack. Very good suggestion though.
jnev
jnev's Avatar
Thanks for the link sapper.
