Henry8601
02.22.2007, 01:30 PM
Oh bollocks...
Right - yeah it was not even connected to a pinion.
I had no idea about the no load thing - I don't think it said anything about that in the manual.
It should be ok as the 20s was for everything - it was not just keep the throttle buried for 20s
A LiPo 8000mah battery is not that heavy, most other people with the wild dagger will run 2X 4000mah Nimh packs and these weigh about 300grams more. Also the power is split between the two brushless systems
