03.06.2007, 08:25 PM
Welcome to the forums!
That controller is good for 70A and 18 NiMH cells. It is good for 2 pole motors only and should run your LMT just fine.
That motor is a very nice one, but a little small for an emaxx if that is what you are planning to use it in. It would be more suitable in a lighter stadium truck or vehicle around 3-4lbs. The amount of voltage you can use depends on the turns on the motor.
