03.06.2007, 08:25 PM
Welcome to the forums!
That controller is good for 70A and 18 NiMH cells. It is good for 2 pole motors only and should run your LMT just fine.
That motor is a very nice one, but a little small for an emaxx if that is what you are planning to use it in. It would be more suitable in a lighter stadium truck or vehicle around 3-4lbs. The amount of voltage you can use depends on the turns on the motor.
Kritical
03.07.2007, 03:11 AM
Thanks for the replies.
Sorry about any misconceptions before, i was running late and had to head to work soon.
yes, I had intended on using it in the emaxx. I remember talking to them on the phone saying it would be fine in it, who knows. Should i just put the titans back in?
As far as gearing goes, im not sure what it is at right now. would have to look into that. The batteries i have a 6 cell matched nimh, but they have been stored for years, will they work?
and this ubec, is that like a battery pack for the rx?
When i had it hooked up before, (when i first got it) i remember it just spazing out randomly, only stuttering back and forth. I was lazy with the wire work so im sure that played into it as well not having this ubec thing...
This truck will mainly be used for bashing, there's an open field not far from my house where some kids built up jumps for their bikes. I'm not looking for insane speed which could be why i got the 1920 in the first place, just something faster than stock than was fun to play around with.
Also, (sorry for so many Q's) what the story behind the emaxx 3.3 or something, wide max? I'm just curious because my truck has the extended proline suspension arms with ue towers and shocks(their older 1/8th scale ones i suppose) and i was wonder if this was any wider or if its the same.
if they is any typos/misspells i apologize but i just got home from work and am ready for bed. ill check this thread tomorrow, thanks again
