Finnster
KillaHurtz
Finnster's Avatar
03.16.2007, 09:03 PM
Originally Posted by ncalenda
Here are some pics:
The front inside: The Front
Now, I do use 2 9V batteries to run my fans, I would rather do this then drain the 14-cell. I know this takes up weight, but not 2 - 3lbs worth. After seeing other trucks that weighed around 9 lbs, I couldn't believe mine was over 12 lbs, about 3 more lbs. That sounds like a lot to me.
Here are the rest
Let me know what you think, thanks!
I would ditch the 9Vs. A 2 sec wheelie will drain more power than the fans will the entire run.
Otherwise you could do little stuff here and there. 12 lbs w/ the batts right? Each 7 cell should weigh ~1lb. So really you are ~10lbs, which is not that bad for a normal Maxx w/ a few alu parts.
