IBJAMMIN
IBJAMMIN's Avatar
04.15.2007, 04:36 PM
The Kyosho spur bolts right up to the CRT.5 diff the only problem is the bearings. Check out RICEMANS post in the brushless section for the details on how to install the Kyosho spur to the CRT.5 diff. Here is a pic of the parts side by side you can see the diference in bearing sizes.
I'm working on the ESC mount now it's going to end up just above the motor in the center of the chassis. :)
Name:	e crt 056.jpg
ID:	2762   Click image for larger version
