Do you guys use thread lock on the motor screws?
Do you guys use thread lock on the motor screws? - 07.11.2008, 08:44 PM
Just installing my new Neu and new MMM and was wondering if you all use thread lock on the motor screws.
Takedown
WARNING: May become violent.
Takedown's Avatar
07.11.2008, 08:58 PM
I dont they hold just fine...
RIP- Tammy (9/14/08)
azjc
07.11.2008, 09:07 PM
threadlock everything......
07.11.2008, 09:23 PM
I put thread lock on mine just in case...I had not put any in w/my 9xl.
zeropointbug
Z-Pinch racer
zeropointbug's Avatar
07.11.2008, 09:34 PM
If you torque them right they will never need it, it just makes a mess if you ask me.
Duster_360
07.11.2008, 09:38 PM
Metal to metal - I always loctite. Vibration will loosen just about anything unless you damp the higher order harmonics - add weight anyone?
Oil or grease will prevent loctitie from developing strength, so I use motor spray to clean threaded part before loctiting.
tc3_racer_001
tc3_racer_001's Avatar
07.11.2008, 10:23 PM
random question, do the motors come with screws or not? thanks.
hyper 8.5 pro SOLD!
Monster Max Still Working...
JR SX3
Neu 1512 2D/S
12t pinion
4800 zippy-r
XRAY xt8
MMM
Neu 1512 3D/F
11t pinion
aqwut
Brushless Heavy Weight....
aqwut's Avatar
07.11.2008, 11:54 PM
I don't use threadlock for motor screws.. just make it nice and snug, because pieces of the threadlock can get through the holes and build up slowly inside the motor can.. but on other chassis parts, I always use light --> medium strength threadlock..
The Power of BRUSHLESS!!!!!
1HP (electric) = 746 Watts.
Everything is brushless!!
What's_nitro?
Soldermaster Extraordinaire
What's_nitro?'s Avatar
07.12.2008, 02:40 AM
I don't threadlock anything. I make sure to check all the screws after a run. I've only had one accident- related to a loose screw.....
DRIFT_BUGGY
DRIFT_BUGGY's Avatar
07.12.2008, 02:49 AM
I don't, but I do use spring washer. But I do check over all screws after every pack
Losi 8ight
MMM V1 w/1.20
Airtronics MX3 2.4Ghz
TP 5S 5000mah
Neu 2.5D/F
coolrunnings
07.12.2008, 02:58 PM
I have never had a motor screw loosen EVER...pinion set screws yes lots of them even after locktighting them.
auto2
07.12.2008, 06:56 PM
if you use it get the tube like gel stuff. only a dot on the threads not a flood so it gets on the screw head. i do not use it on motor screws and i check them every run. i use it on center diff /motor mount chassis side and the screws that hold the belcranks in . and ALWAYS on the pinion. sometimes the shock mounts wil loosen. nyloc nuts only work once.
George16
Supermaxx
George16's Avatar
07.12.2008, 10:20 PM
I use blue loctite on every metal to metal connection unless I'm using a lockwasher on the screw or bolt.
Predator with OS .21TM
Supermaxx with Mach .26
Revo with OS .18TZ
Kyosho ST-RR Conversion
jnev
jnev's Avatar
07.13.2008, 02:30 AM
I also use loctite on every metal to metal connection... except for the motor screws. Never had a motor ever come loose. Just have to torque it down pretty hard.
zeropointbug
Z-Pinch racer
07.13.2008, 04:12 PM
Yeah, spring washer screws are very good in fact... use traxxas motor screws, they are the best for holding on to these brushless power houses.
