my mmm is working but where is the USB
auto2
my mmm is working but where is the USB - 06.09.2008, 07:35 PM
ok where is the usb plug on this MMM?
so far it is working but brakes HAVE to be adj before i do an endo.
gogglespaesano
gogglespaesano's Avatar
06.09.2008, 07:41 PM
you should have gotten an adapter with a usb on one end and the other end plugs into the plug that plugs into your receiver. If that was a little too confusing...unplug the esc from your receiver and plug it into the adapter cable. There is no actual usb on the MMM itself, you have to use the adapter.
Hope that helps, maybe someone else can explain it better if not.
azjc
06.09.2008, 07:54 PM
it uses the Castlelink like the Mamba 25 does
link....http://www.impaktrc.com/product_info...oducts_id=2374
but one should have come with your MMM
DRIFT_BUGGY
DRIFT_BUGGY's Avatar
06.09.2008, 08:13 PM
You can read about the Castle Link on the CC site http://www.castlecreations.com/produ...stle_link.html
Losi 8ight
MMM V1 w/1.20
Airtronics MX3 2.4Ghz
TP 5S 5000mah
Neu 2.5D/F
auto2
06.09.2008, 10:14 PM
i figured that but the 2 plugs didnt fit togeather without grinding that tab off.. have to put my reading glasses on.lol/ thanks
azjc
06.09.2008, 10:50 PM
the RX plug fits in the Castlelink only 1 way if it doesnt fit flip it over and it should fit
auto2
06.10.2008, 06:38 AM
hey reading glasses work.LOL i was removing my steering servo plug .(dumb) heat stroke .LOL
Fast5sRevo88
06.10.2008, 12:32 PM
While we're on the basic subject, can i use that same adapter to set my CCBEC to run at 6v instead of 5.1v?
Superbasher
Superbasher's Avatar
06.10.2008, 12:50 PM
I would imagine so, as long as you can change it from a PC.
  Send a message via MSN to Superbasher
auto2
06.10.2008, 01:37 PM
it wont enter manual programing mode either . hold full throttle and turn on thing. ill update software tonight and report back.
auto2
06.10.2008, 08:58 PM
fixed. update did the trick
azjc
06.10.2008, 09:31 PM
yes and do it before you connect the BEC to the wiring if you do it after it can confuse the program about whether to link to the ESC or the BEC
DRIFT_BUGGY
06.11.2008, 12:05 AM
Yes, I used the one that came with my MMM and worked fine
Losi 8ight
MMM V1 w/1.20
TP 5S 5000mah
Neu 2.5D/F
DRIFT_BUGGY
06.11.2008, 12:08 AM
Oh, so everytime you want to program the BEC you have to un-solder the battery wires? Does this also work with the ESC then?
Losi 8ight
MMM V1 w/1.20
TP 5S 5000mah
Neu 2.5D/F
tc3_racer_001
tc3_racer_001's Avatar
06.11.2008, 02:19 AM
id imagine you would only have to unsolder one? glad to know (i just assumed that this was the case)
hyper 8.5 pro SOLD!
Monster Max Still Working...
JR SX3
Neu 1512 2D/S
12t pinion
4800 zippy-r
XRAY xt8
MMM
Neu 1512 3D/F
11t pinion
