Originally Posted by Revracer
Are you running an actual e-revo or converted? And from what I've seen, every motor in the world is going to get hot after about 10 minutes of hard running... Do you have any videos of the truck? Or will you be taking any?
I'm running the actual New E Revo that was just released.
I know the inrunners run warm, but if geared properly I believe they should keep temps in check. At least in the 160 to 170 range. Cooler than that would be even better, if possible.
I may make a few vids of the truck once I get it perfected.
There are several motors here that I have on hand. Plans are, to try each one until I find my favorite, most powerful setup.
The Nemesis 14xl I just took out of the truck is going to be hard to beat. But it needs to be fed on 6S. So until I get my Monster Mamba, I'm going to set the 14xl to the side and see what else I can come up with.
Instead of the 20/68 gearing, maybe 16/68 would work better.
