Hey guys i have a problem with my v balancer, im using a duratrax ice charger with the appropriate power supply.
When i plug my 4s 5000mah flightpower pack into the v balancer it shows that i have a low voltage warning (red bar flashing) but when i check through all the cells on the menu they all have 3 bars for all 4 cells. There is no low voltage yet the balancer wont let me stay in link mode since it is detecting a low voltage??
Any help would be great!
Losi 8ight e
MMM / Neu 1512 2.5d/f
Thunderpower 5s 5000
did you some how go below the LVC on the battery. Also does it charge AND balance at the same time for the other batt with no problem. If it does than the problem is the battery itself
I dont understand why flightpower added the extra red wire??
All is well after i removed this wire on my balance adaptor.
Thanks guys !!
No probs, but don't understand too why it's like that. When i've bough my FP 5000mAh, 4s pack, i had to remove this wire too, if not, nothing to do, incapable to charge it, always an error message on the balancer.
