need tire opinions on glue and rims
e-rev project
need tire opinions on glue and rims - 01.10.2009, 04:42 PM
so i just got my ebay auction, duratrax warhead stock tires, and proline road rage tires with half offset rims. http://cgi.ebay.com/ws/eBayISAPI.dll...m=220335715421
the road rage's have off set rims, the duratrax don't. all tires were barley glued so i removed them from rim. the rims are almost brand new, the chrome isn't even flaking.
Question is should i keep the road rages on the offset or use the offset rims the offroad tire?
also for tire glue anyone try http://www.gorillaglue.com/glues/superglue/index.aspx it say impact strength
or is tire specific super glue really that much better (shock resistant) and what not
also do you know what brand the blue rim is?
lastly is 13.6 oz heavy for a monster truck tire w/ rim and foam ?
sorry for question purge
thanks
Andrew32
01.10.2009, 04:56 PM
i would advise using the medium thickness super glue main cuz they will come off clean when you boil them to change tires. Not sure if gorilla glue will
jayjay283
jayjay283's Avatar
01.10.2009, 05:25 PM
Only dudes I know who make blue rims are RPM. I dont know the glue from experience but I heard it turns brown and takes a turd after a few weeks.. get some thin super glue. $4 cant go wrong
e-rev project
01.10.2009, 10:31 PM
for the thin or medium glue recommended is that just any CA or tire specific
. and what makes tire specific glue any better or is it just CA labeled for my ignorance
01.10.2009, 10:49 PM
as I understand it(my educated guess) super glue is ca glue, and isn't tire specific. I have used super glue and ca tire glue interchangeably and gotten the same results.
gorilla glue, silicone, anything you want will hold a tire on, with ca or super glue tere are ways to get the tire off
E-Revonut
RC-Monster RC8T
E-Revonut's Avatar
01.10.2009, 11:28 PM
Skip the glue and get a set of beadlocks!!! I don't know if I'll ever run glued tires on my MT ever again!
01.10.2009, 11:34 PM
I run silicone with my beadlocks. I've tried pro-lines, axials, and maximizers, and like maximizers the best, but have still had the bead pull out in spots. The silicone gives a little extra hold and cleans up fairly easily.
