range issue with d3xs
e-mike
e-mike's Avatar
range issue with d3xs - 04.25.2009, 03:25 PM
after my mmmv3 died today now its time to my brand new dx3s to have issue...im not able to pass 100 feets without the esc cut...or loosing bind...W.T.F all this problem became to make me feel very sad....im really close to sell all my stuff...o yes very close
ive tried 3 other rx and same thing.....
D8t on juice!!
lutach
lutach's Avatar
04.25.2009, 03:33 PM
In my last video, you can see that I lost signal to my truggy. I'm using a JR R-1 with the Spektrum module and the Rx in my truggy is the SR3000. I also had it happen breafly in my MLST with the same radio, but the with the micro Rx.
e-mike
e-mike's Avatar
04.25.2009, 04:00 PM
not good to read!!!!
D8t on juice!!
lutach
lutach's Avatar
04.25.2009, 04:03 PM
I forgot to mention I was a little further then 100 feet though. Some places do cause something to happen to the 2.4G stuff and some don't. I can't explain it, but it can get a bit frustrating. Good thing the ESCs stop when they loose signal. I have to check placement of my Rx in the MLST though.
eovnu87435ds
A 16yr old with a combover
eovnu87435ds's Avatar
04.25.2009, 04:23 PM
another mmm v3? also, does this happen in other instances? like what if you take the tx and rx to a place you normally arent at, have the rx just powered on from a rx pack, then test range... Also, make sure your rx isnt loosing power. I thought I had the same issue in my rustler, but it was my BEC shorting and cutting power to the RX
Hyper 7
BARBIE JEEP!!
CRT.5
TC4
RC18B
PedeBasher
PedeBasher's Avatar
04.25.2009, 05:09 PM
Same thing happens with my DX2.0 about 100ft down by my neighbors house. Its unexplainable and was a freak thing. My thought is a trucker with a CB radio was driving by and caused some freak reaction.
And as said before, a number of things can cause Spekky radios to go bazerk. CB radios are, as far as I know, the number one cause. Maybe like what happened to me, a trucker drove by and caused your DX3S to go nuts? Or maybe a plane/heli? Could be anything.
Did you know?
  Send a message via AIM to PedeBasher
e-mike
e-mike's Avatar
04.25.2009, 06:33 PM
i just changed the setting in my tx(frame rate)and now its seem betterdont know if this setting could help but its seems to work...
D8t on juice!!
rawfuls
roofles.
rawfuls's Avatar
04.25.2009, 07:14 PM
Could be a brownout, have you tried elsewhere?
Jeremy1976
04.25.2009, 11:10 PM
I had the same issue with my DX3s. It glitched a couple times and cut out. I replaced the batteries and it seemed to clear up the symptoms. I did buy a Futaba 3pk FASST though and would never look back.
e-mike
e-mike's Avatar
04.25.2009, 11:38 PM
this is the thing that i want to do...trade my dx3s for a 3pm or just buy a 3pm
but tonight ive try elsewhere and everything was ok....so maybe a bad signal in my area
D8t on juice!!
