Go Back   RC-Monster Forums > Support Forums > Team Tekin
using the RS pro in a 1/8 converson?
whitrzac
Can't catch this...
whitrzac's Avatar
using the RS pro in a 1/8 converson? - 03.01.2009, 03:09 PM
will the tekin RS pro handel a novak 4.5 550 sized motor on a 4s?
I have a pair of 35v caps, but no bec, so for now I plan on using a RX pack... enless the internal bec will work??
my plan is to convert my old hyper 7 since they have no resale value...
jhautz
jhautz's Avatar
03.01.2009, 04:19 PM
I would think it should be fine. Just pull the red wire on the RSPro and use the Rx pack. The BEC wount hold up to 4s. Watch your gearing to start with untill you get a feel for motor and esc temps.
I've run a R1Pro for long time in a 1/8 scale buggy and had great sucess with it so I would imagine that the sensored version should be fine as well. I know the R1 and RS are basically the same thing except for the sensor wire port. In all honestyyou probably dont even need to use the sensor wires, it should run just fine in sensorless mode.
to make it...
or break it...
Silent...But Deadly
TekinTeamMgr
TekinTeamMgr's Avatar
03.02.2009, 04:52 PM
Yes you can. Jhautz is correct you will need to remove the red wire to do this. The RX pack or seperate BEC will be needed to power the radio system.
This was answered in the Tekin forum as well.
  Send a message via Yahoo to TekinTeamMgr
whitrzac
Can't catch this...
whitrzac's Avatar
03.22.2009, 12:31 AM
http://www.rc-monster.com/forum/show...135#post272135
TekinTeamMgr
03.22.2009, 11:00 AM
Whit, make sure your timing is turned down to like 0-10.
whitrzac
Can't catch this...
whitrzac's Avatar
03.22.2009, 08:17 PM
its a sensorless, and the timeing is at 0 on the speedo, IDK...
could it be the 4mm bullets between the motor and esc? I havent goten to the LHS to get some 5-6mm ones yet
TekinTeamMgr
03.22.2009, 09:29 PM
I doubt it. Make sure to cut the motor wires to equal lengths, it helps. A bad connection certainly could cause that issue.
whitrzac
Can't catch this...
whitrzac's Avatar
03.22.2009, 09:43 PM
but it only cogs trying to go backwards..
whitrzac
Can't catch this...
whitrzac's Avatar
03.23.2009, 09:16 AM
one little thing I noticed, you can't re calibrate the esc when using a external BEC....it just sits there trying to find neutral.
crazyjr
crazyjr's Avatar
04.29.2009, 07:14 PM
for programming, you need to reattach the red wire and use a 2s pack
whitrzac
Can't catch this...
whitrzac's Avatar
04.30.2009, 08:21 AM
lil late now...
the RSpro is being sold for an RX8
