Revo Truggy
jzemaxx
Revo Truggy - 03.16.2009, 03:53 PM
Here is my revo MT/Truggy. Perfect weight distribution....
Tranny is set backwards for the motor to hang forward to hang the weight towards the front. With twin 3's its perfect 50/50. Truck runs 39mph on 3S and after 30min run, the motor is 110-115 and ESC is 101-105. Awesome setup....weighs 9.5lbs exact without batts.
ID:	6611   Click image for larger version
ID:	6612   Click image for larger version
Serpent S811-E Tekin
Revo 3.3 BL- 1515 1Y
Mugen MBX6 NEU/MMM
Mugen MBX6-T NEU/MMM
Losi LST2.0 MT NEU/MMM
Losi 8T RTR 2.0 NEU/MMM
Losi 8T 2.0 NEU/MMM
Losi 8B-E 2.0 NEU/MMM
03.16.2009, 07:24 PM
Looking good! Are you still running 4wd.? If so, can you snap a pic. of how you mounted the trans.... I am in the process of converting my 3.3 Revo and I am looking for new ideas....
Thanks!
jzemaxx
03.16.2009, 08:07 PM
Yes 4wd...using emaxx driveshaft.
Mugen MBX6 NEU/MMM
Losi 8T 2.0 NEU/MMM
03.16.2009, 08:21 PM
How was mounting it...problematic or simple? I like the idea...it is based on the GR3 chassis, but at a fraction of the cost!
jzemaxx
03.16.2009, 10:29 PM
Just made a custom mount under to bolt the trans to on one side and bolted the other side to the factory frame. Took it to the track today...wow. Working on the suspension a little more to tweak some bounce out of it. Since it came out ligther then expected, the suspension was setup for heavier setup.
Mugen MBX6 NEU/MMM
Losi 8T 2.0 NEU/MMM
mopar1994
mopar1994's Avatar
03.17.2009, 07:42 PM
is that the e-revo tranny? did you have to drill new holes in the chassis to mount it? and i would also like to see a pic of the bottom
jzemaxx
03.17.2009, 07:49 PM
No...emaxx 3905 transmission.
Pics coming
Mugen MBX6 NEU/MMM
Losi 8T 2.0 NEU/MMM
03.17.2009, 07:58 PM
Would this trans. set up work on my Revo chassis?
http://www.rc-monster.com/proddetail...MX07-TR&cat=17
I like your idea a lot and am considering doing this mod.
jzemaxx
03.17.2009, 08:20 PM
You can see I run bolts through the frame and the bracket and sandwich the trans in. It won't move not one bit. Ran it at the track yesterday for over 2 hours. Absolutely ran away from a E-revo that was with me at the track with the same basic setup. Its just much lighter on its feet and handles alot better. Also because its a lightweight setup I was able to gear it quite aggressively on lower voltage. Motor, controller and batteries have yet to go over 120. That was over an hour of laps...non-stop, just swap batteries and go. Running 10,000 mah so runtimes are LONG.
ID:	6621   Click image for larger version
ID:	6622   Click image for larger version
Mugen MBX6 NEU/MMM
Losi 8T 2.0 NEU/MMM
jzemaxx
03.17.2009, 08:11 PM
Probably would, but I like the 3905 trans since it places the motor in the middle
Mugen MBX6 NEU/MMM
Losi 8T 2.0 NEU/MMM
03.17.2009, 08:13 PM
I forgot about that....good point.
03.17.2009, 08:23 PM
Did you do any mods to your trans?
jzemaxx
03.17.2009, 08:26 PM
nope....the 3905 tranny is brushless ready. So far its bulletproof. Ran it on 5S last night for giggles....57mph on the GPS.
Mugen MBX6 NEU/MMM
Losi 8T 2.0 NEU/MMM
03.17.2009, 08:42 PM
Would it handle 6s...because that is what I will be using
jzemaxx
03.17.2009, 08:54 PM
No problem....
Mugen MBX6 NEU/MMM
Losi 8T 2.0 NEU/MMM
